Simple question about analog signal muxing w/ case structure
Hello!
I am trying to generate a signal as follows:
-if the clock signal (square wave in vi) is 1, then select the sine wave
-if the clock signal (square wave in vi) is 0, then select the DC
So, I've designed the vi like this.
-  vi for the "False" case (for DC)
-  vi for the "True" case (for sine wave)
And the result is as follows.
The output seems like the case structure is always on "False".
Is there any way to generate a desired signal?
(959 Views)
Hi TSMC,
what would happen when you get rid of all those ExpressVIs and their DDT wires and use simple plain LabVIEW functions?
Btw. you know we cannot run/edit/debug images with LabVIEW. When you have problems with your code then you should attach your code!
(936 Views)
