Simple question about controlling LED indicators with left and right arrow keys.
Let's just suppose you want to control 5 led indicators using two buttons "left" and "right" just like the screenshot that I have uploaded. You want the middle one to be light up at first then for example if you press right button, then the middle one just goes off and the right next to it, lights up. Preferably, key binding each of the buttons to the right and left arrow on the keyboard. How would you do that?
Message 1 of 9
(3,467 Views)
You need a event driver state machine to do such thing.
  • Use a event structure within a while loop
  • Add value change events for the left and right buttons
  • Initialize a boolean array of size 5, set the index-2 as True
  • Based on the button changed, do a logical shift (right or left) on the array and display the values using the LEDs
  • Keep track of this array value in a shift register in the while loop (this way any changes is with respect to the previous state)
Santhosh
Soliton Technologies
Message 2 of 9
(3,452 Views)
The easiest is to change your LEDs to an array of LEDs. Initialized it to 00100, then use either a timed loop or event structure and Rotate array when one of the buttons are pressed. How to bind a key to the button? Button Properties.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 9
(3,425 Views)
How do I do that?
If you could make sample, would be grateful please.
Also, why does auto indexing an array inside a while loop gives me error but a for loop does not? How to fix it
Message 4 of 9
(3,409 Views)
 You can resolve this by this way :
Loïc.
Message 5 of 9
(3,403 Views)
Accepted by topic author Seiryuu90
Few Modifications
1. 3rd element is True by default
2. The order of Cluster is changed to avoid array reversing and readability
3.You can use -1 instead of Rotate 1D array to Left Shift.
4. Also, I guess it should limit Movement once it reaches its extreme right/left
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 6 of 9
(3,374 Views)
It is very nice of you guys to do the homework for the OP. Unfortunately, they will not learn LV that way. 😁
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
Message 7 of 9
(3,364 Views)
Trust me I'm learning just fine thank you for your concern. Goodnight.
Message 8 of 9
(3,355 Views)
Thank you and Loic much for your help.
Message 9 of 9
(3,348 Views)
