Simple state machine
Hi everyone,
i have written a very small and simple state machine. (used project template).
Unfortunately i can onnly start one time. But if i´m testing with highline i have no trouble. Perhaps someone can give me some advice.
And how can i block push/activate button during sequence?
Thank you in advance
(3,409 Views)
Hallo Hulk,
I can run your main VI several times without any problem: why can you "start only one time"?
To disable (and gray out) buttons you can use a property node for that button…
Suggestion:
Don't close the VISA reference in the VI when you want to start your "Sequenz" again…
(3,372 Views)
I think you have to 'Reset' the Express VI 'Verstrichene Zeit' if you press 'SEQUENZ' for the second time after starting the VI.
(3,368 Views)
Hi everyone,
in highlightmode  it works fine...really no trouble.
But in live mode i start sequence, first ACW, delay, IR...
Then i pushed again sequence and the device is like "overload/to much input".
The timer is set to reset automaticly with true bool and i moved the close visa reference to exit case.
Perhaps it helps.. i put an indicator to "time has elapsed" after one sequence..he is always true...
(3,309 Views)
