Simple use of subpanels?
I've long ago lost track of this thread--you should probably post your question as a new topic.
Allan
Message 11 of 19
(2,390 Views)
 how to open the same  vi in multi sub panel one by one and closing  also....
Message 12 of 19
(1,981 Views)
 i   have already posted....
Message 13 of 19
(1,972 Views)
Are you talking about the same instance of a VI or different clones of the VI?  You can have different clones be in different subpanels, but a single instance can only have a front panel open once, which means it can only be in one subpanel.  Perhaps you should better explain what you are trying to do.
Message 14 of 19
(1,937 Views)
My task is...
i have 5 subpanels i am trying to load same vi in all subpanels one by one . I will close any one vi in the subpanel and  i load same  vi whic is emty subpanel..if have any example or solution share with me...
Message 15 of 19
(1,920 Views)
aike-lv wrote:  i am trying to load same vi in all subpanels one by one .
You did not exactly answer my question.  Is this VI a reentrant VI and you are trying to load a different instance of it into the different subpanels?
Message 16 of 19
(1,907 Views)
i am opening the vi in  reentrant mode...
Message 17 of 19
(1,889 Views)
Can you share your code so I can better understand your setup.  There are many ways to call reentrant VIs and I want to make sure we get the right way of getting the reference.
Message 18 of 19
(1,885 Views)
send the text mail to aikenlv65@gmail.com.. i will send  my code...
Message 19 of 19
(1,875 Views)
