Simulate Arbitrary signal generator locks up after loading lvm file
After loading a .lvm file in the Simulate Arbitrary signal generator the VI locks up (or Labview) and I need to kill labview with windows task manager.  I configuire the Arbitrary signal generator to repeat X values (0,1,2,0,1,2) and entire signal each iteration. I click on define Signal and load the file I have included as an attachment to this post. I 12507 samples with a Dx of 4n. The file loads and it shows up in the define signal graph but then clicking OK does not work and neither does cancel>. I have to use task manager to kill labview. Is 12507 samples too much for the Arbitrary signal generator?  I tried loading a file with only 10 data points and that worked OK. Could my Dx of 4 nanoseconds be the problem? I'm really stuck here and would like to simulate this waveform I have. Help is greatly appreciated.
(3,069 Views)
I don't know anything about .lvm files or that express VI, but this will turn your data into a waveform graph.
(3,047 Views)
Thanks, I'll take a look at it.
(3,040 Views)
