Simulate CAN-Bus Communication
Hi there,
I need to create a Sub-VI, which can receive messages on a CAN-Bus-Device (NI-9861). However, I do not have the device myself, so I need to simulate that.
I do know the content of the two (2) messages, that will be send on the CAN Bus, which is:
ID 1100:   Byte 0-3 DINT, Byte 4-5 INT, Byte 6-7 UINT  (8 Bytes total)
ID 1105:   Byte 0-1 UINT, Byte 2-3 UINT, Byte 4-5 UINT (6 Bytes total)
Can I send those messages over my virtual CAN-Bus-Port (which is CAN256 and CAN 257, as I understand) via NI-Max?
How can I receive them once I sent them?
Would I need a VI to both send AND receive my messages?
Thanks you for your help
Martin
(3,177 Views)
Hi mw,
You can send those messages from another VI. Create a simple VI to send those messages…
(3,168 Views)
Thank you @GerdW for the clarification.
I just found the examples "CAN Receive" and "Transmit Receive same Port" via the LabView Help Example Finder.
I think I can go from that code and modify this, so I can send and receive my exact messages with my timing over the virtual ports. After that, i should be able to modify the "CAN Receive" for my needs.
(3,153 Views)
