Simulate ECG Signal Source will not install from BME Startup Kit
Hi, I'm having a problem getting all the VIs that are supposed to be provided with the BME Startup Kit to install, namely the Simulation ECG Signal Source VI. I have the two toolkits, Vision, and DAQmx driver installed. When I go to try to used the VI, there is a large question mark where the selection button normally is for a VI, and the VI does not show up in the Biomedical pallette directory. Can someone please give me some insight as to what might be the problem? If you need more information, I'd be happy to provide it.
Thanks!!
Message 1 of 15
(5,700 Views)
What is the BME Startup Kit and where did you get it from? I don't think that is something that NI sells or distributes so have you asked the provider? What is the name of the missing VI?
Message 2 of 15
(5,686 Views)
The startup kit is offered free for download by National Instruments here: http://zone.ni.com/devzone/cda/tut/p/id/6626. The name of the missing VI is "Simulate ECG Signal Source."
Message 3 of 15
(5,675 Views)
I can't download the toolkit right now. It might take me a while to get to this. Maybe someone else can help.
Message 4 of 15
(5,671 Views)
I finally got around to downloading the toolkit. I got the 8.5 version and the Simulate ECG Signal is on my palette (top row, upper right).
Message Edited by Dennis Knutson on 04-12-2008 10:44 AM
Message 5 of 15
(5,648 Views)
Is there any reason why the ECG VI in particular might not install that you can think of?
Message 6 of 15
(5,633 Views)
It does require the full version of LabVIEW - not the base version. That's the only thing I can think of. I had a look at the code for the express VI and besides the subVI (subSimulate ECG Signal.vi in the user.lib\_express folder), it uses standard VIs in the full version of LabVIEW (i.e. Sine Waveform, Uniform White Noise). If any subVI is missing, you will get the '?' on your palette. For example, I don't have Vision installed so I have the same thing for those on the imaging paletttes.
Message 7 of 15
(5,626 Views)
Thank you very much for your help, I finally got it up and running thanks to your insight!
Message 8 of 15
(5,620 Views)
i have download biomedical startup kit for labview 8.5 and i use professional development system versions but i can't  access Simulate ECG Signal.vi they just only ? simbol (look attachment files). why i can't access them maybe someone can explain that and help me to solve  this problem  cause  i really need that. can labview 8.0 professional development system versions use biomedical startup kit if yes can someone tell me what is the address.tanx
Message Edited by marp84 on 06-09-2008 09:29 PM
Message 9 of 15
(5,410 Views)
My problem ended up being related to the fact that I had installed LabVIEW onto a drive other than the C:\ drive on my computer. For some reason that keeps the Simulate ECG ExpressVI from installing to the computer. I visited NI and they provided me with a copy of that ExpressVI which I added to my functions palatte manually and it works fine. If you can provide an email address, I can send you the Simulate ECG VI. I should warn you, though, the VI is a little hacked together and does not do a fantastic job of simulating a realistic ECG.
Message 10 of 15
(5,401 Views)
