Simulate a control of a sine wave signal
Hi Xebe,
unfortunately I'm stuck at LV2014 here, so could you please resave your VI for LV2014 and attach it again?
Message 11 of 18
(2,021 Views)
I hope I did it correct.
Thanks for keeping up with me.
Message 12 of 18
(2,019 Views)
Hi Xebe,
wow, you did it the "hard" way using the simulation toolkit. (I don't have this toolkit installed and so cannot run your VI.)
I was talking about the PID toolkit, available for free with recent LabVIEW versions (atleast better than Base version)!
Message 13 of 18
(2,013 Views)
So you just mean the PID block?
I'll try to use that one instead and keep you updated
Edit: Something more like this (attachment)
Message 14 of 18
(2,003 Views)
Hi Xebe,
I simplified your VI even more!
Keep in mind: this simple VI does not include any "plant simulation", so the PID controller has no chance to ever reach its setpoint as the "control system" does not react on the PID output signal…
In the example finder you will find VIs demonstrating PID with some plant simulation included!
Message 15 of 18
(1,998 Views)
Thanks a lot, this was very helpful.
Do you perhaps know if there's a way so that the PID only works when the PV goes outside the set limits?
Message 16 of 18
(1,993 Views)
Accepted by topic author XebeXUC
Hi Xebe,
With "real" PID controllers (available as hardware block) you most often have a deadband setting which exactly does what you request now.
You can fake this in LabVIEW quite easily:
IF ABS(pv-sp) <= deadband/2 THEN
  pv:=sp
ENDIF
output := PID(pv, sp)
 You find other threads on this topic in the forum…
Message 17 of 18
(1,988 Views)
where exactly would i put in this code?
And where do i fill in my high and low value between which it doesn't have to work? (I have little basic knowledge about code write programming)
Edit:
Found out a solution for the problem that seems to work.
Thanks a lot for your help and patience with me.
Message 18 of 18
(1,980 Views)
