Simulate arbitary signal
Thir part is related to the first part. I want to write the data for the signal generated. The simulate signal generates only one timeperiod my rest of the code generates data for about 1000 periods. Is there some settings which is wrong in the simulate arbitary signal vi. which i need to do so that it produces a complete signal not just one time period of wave.
Message 11 of 12
(290 Views)
I don't understand what you mean. Each time that the simulate function is called, you get the entire waveform that you have defined - all 998 points. That is a complete signal as you defined it.
Message 12 of 12
(279 Views)
