Simulate reactance LC tank
Hi, can anyone help me with this:
I'm trying to simulate the reactancia of a paralel LC circuit, i want to  put in a grafic  (Reactance vs Frequency) the reactance oe the paralel LC circuit  when i  insert a sinusoidal signal.
How can ai start, any tips
Regards David
Message 1 of 9
(5,150 Views)
Well, reactance is the imaginary part of impedance, and for an LC circuit, the impedance is all imaginary (assuming ideal components). Thus, you can simply calculate the reactance as a function of L, C, and frequency. You can get the exact equation from wikipedia:
Message 2 of 9
(5,145 Views)
Here's a simple VI that calculates the impedance of a capacitor, inductor, and resistor all in parallel. If you don't want the resistor, just make its value very large.
Hope this helps,
Ed
Message 3 of 9
(5,106 Views)
Hi Ed,
could  I trouble you to post your VI saved as LV8.0?
Jim
LV 2020
Message 4 of 9
(5,098 Views)
No problem. Here it is in 8.0.
Ed
Message 5 of 9
(5,087 Views)
Should Impedance go down at the resonant frequency of parallel LC? Like at 2.013 MHz for 2.5 µH and 2.5 nF?
____
Ryan R.
R&D
Message 6 of 9
(5,085 Views)
In a parallel circuit at its resonant frequency, the magnitude of the impedance will be at maximum since the respective reactive currents in the inductor and the capacitor cancel, leaving only the conduction of the resistor. As a mathematical consequence, since all the imaginary currents cancel, the impedance is purely real; hence the imaginary component of the impedance goes to zero as the frequency approaches resonance.
If, however, there is no resistor in parallel with the L and C, the magnitude of the impedance goes to infinity at resonance and its phase is undefined.
Ed
Message 7 of 9
(5,080 Views)
That's what I thought. The reactance should go from Capacitive to Inductive, or vice versa when it crosses the resonant frequency. Nice VI. 🙂
____
Ryan R.
R&D
Message 8 of 9
(5,074 Views)
Handy tool.  Thanks Ed.
Jim
LV 2020
Message 9 of 9
(5,046 Views)
