Simulate signal block with DAQ Assistant digital output NI 9375
I would like to connect the simulate signal block to the DAQ assistant where I am using an NI 9375 digital output, I have attached a photo. What conversion block do I need?
(2,449 Views)
Hey Wakeel,
The answer depends on what exactly you are trying to achieve. Output just one value to a single channel? Outputting a waveform over time? If so, do you want the Simulate Signal ExpressVI to generate the whole waveform at one, or should it do so point by point?
You are asking for a "Conversion Block". If your question is about the small function bottom right in the screenshot, then it's Convert from Dynamic Data you are looking for.
Please attach your current VI, that makes easier to help you.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,414 Views)
