12-30-2020 12:52 PM
Yes indeed you need a resistor to limit the current.
So the led can turn on and then turn off every second with this code?
12-30-2020 01:02 PM
I have one last question for this part of led simulation: what exactly do the two DAQmx which are on the right ?
12-30-2020 01:03 PM
Did you try it?
Simulating Work ain't the same as doing work.
12-30-2020 01:17 PM
I will receive the material on Monday or Tuesday so i can't test immediately. I prepare the code to try as soon as the hardware is here.
12-31-2020 02:09 PM
Which DAQmx things are you talking about?
01-01-2021 04:17 AM
It's ok, i understood how they work. I will test the program as soon as the material arrives and i will keep you informed.
