Simulate the opening and closing of a solenoid valvve during every second
Yes indeed you need a resistor to limit the current.
So the led can turn on and then turn off every second with this code?
Message 21 of 26
(841 Views)
I have one last question for this part of led simulation: what exactly do the two DAQmx which are on the right ?
Message 22 of 26
(838 Views)
Did you try it?
Simulating Work ain't the same as doing work.
Message 23 of 26
(838 Views)
I will receive the material on Monday or Tuesday so i can't test immediately. I prepare the code to try as soon as the hardware is here.
Message 24 of 26
(832 Views)
Which DAQmx things are you talking about?
Message 25 of 26
(813 Views)
Accepted by topic author drsisco
It's ok, i understood how they work. I will test the program as soon as the material arrives and i will keep you informed.
Message 26 of 26
(806 Views)
