Simulated NI-9361 module not available to detect in LabView
Hey all,
I have configured 4 different simulated NI modules (figure 1). However, I'm not able to detect the NI-9361 module in LabView Front Panel (figure 2). I wonder if anyone has faced a similar problem and knows I could procced.
Figure 1. The 4 configured modules.
Figure 2. Selection of module pins in LabView Front Panel, as it can bee seen the FlowMod (IN-9361) is not available to be selected.
Additional info
- I'm using LabVIEW 2021 SP1.
- The other 3 modules work correctly and I'm able to read from all their pins.
All help is appreciated!
Kind regards,
Hossein
(1,531 Views)
Hi Hossein,
Figure 2 does not show a "LabVIEW frontpanel". Most probably it shows a dialog to select a channel within the DAQAssistent ExpressVI!
The NI9361 is a CTR module, while the other 3 are AI modules. When you start the DAQAssistent to get AI values then it will not present CTR channels…
(1,523 Views)
Hey GerdW,
Thanks for your response. You're right, figure 2 does not show the Front Panel, it is a screenshot of a window that pops up when one needs to select a physical channel in Front Panel.
 Any suggestion on how I should proceed?
For the other three modules I'm using DAQmx to create virtual channels, figure below shows the setup I'm using for Current measurement. Do I need to use some other component than DAQmx to read from a CTR module or can I just change the DAQmx setup? And any suggestions on a link, where I can read more about AI and CTR modules?
Kind regards,
Hossein
(1,501 Views)
Accepted by topic author HosseinBakhtiari
Hi Hossein,
Place a new CreateVirtualChannel, set it's instance to any of the "Counter" modes. Then create a DAQmxChannel control by right-clicking the corresponding input of CreateVirtualChannel. Now the control should allow to look for counter channels.
One more thing you could try: at edit time right-click the DAQmxChannel control and select "IO name filter". A dialog will open where you can choose which kind of channels you look for…
On your VI:
  • Do you really need 8 shift registers to hold the values of 8 channels? Why not use one 2D array to hold all channels?
  • Do you really need to call that scaling function 8 times, once for each channel? Wouldn't it be easier to scale all samples at once - or even apply a DAQmxScale at the CreateVirtualChannel function?
  • Building that XY graph also is much easier once you use a FOR loop for all channels…
  • Appending samples to evergrowing arrays is highly inefficient for the memory manager!
  • As soon as you read the first ~1000 samples you have more samples in your arrays than your graph is able to present - highly inefficient…
  • You set a samplerate of 10S/s, but you limit your loop to read just 2S/s! This is highly inefficient and begs for errors later on! When you define a samplerate then you should NOT add another WAIT inside the DAQ loop…
(1,478 Views)
Hey GerdW,
Thank you for your help, the first suggestion worked!
PS. thank you for your feedback on the VI, it is just a first sketch for the reading part of the program, but I'll definitely consider your suggestions and use them!
Kind regards,
Hossein
(1,441 Views)
