Simulated NI9205
I am simulating an NI 9205 (32-Ch +/- 10 V to +/- 200 mV 16-Bit Analog Input).
I would like to know if the LabView simulator allows one to simulate an input signal so that we can develop a test application before purchasing the board.
Thanks in advance.
(3,238 Views)
Hi Cyclops.
Yes, you can simulate an NI 9205 and use it in LabVIEW to develop your application before purchasing the board. However the signal will always be the same. For example, for analog input is always a sine.
This tutorial should help you: http://www.ni.com/white-paper/3698/en
I hope this help.
Ricardo Ramos
Account Manager
+5511989658513 | ni.com
(3,202 Views)
Hello Ricardo,
Thank you very much for your speedy reply. The information was truly useful.
I have just one more consult. For the NI 9205, I can simulate a cDAQ chassis using the NI-DAQmx Simulated Devices. This simulation tool comes with NI-DAQmx.
Is there anyway to do something similar with a CompactRIO chassis? I am able to simulate a CRIO chassis inside a new project, but I am unable to find the simulated equipment in MAX in order to then simulate a signal in the analog channels.
Thanks in advance.
(3,190 Views)
No, from what I know, this is not possible. But you can simulate the analog channels by using functions generators.
Ricardo Ramos
Account Manager
(3,182 Views)
