Simulating Keyboard Std In/Out in cmd
Hello All,
I have a .bat file which I run using System Exec VI.
After starting, the user will be required to hit 1 twice so that the programme can be executed. I want to avoid hitting the keyboard, so I can send this through labview so my programme runs fully Automated without any Input from the user.
I tried this without success maybe someone has an idea how I can implement this. Also I will like to read the result from the cmd window after the execution.
thanks in advance for your suggestions
Message 1 of 8
(8,114 Views)
So why not prompt for user input within Labview before starting the CMD?  That way, the CMD prompt is only used for running the compile routine.
aputman
Message 2 of 8
(8,089 Views)
After rereading your question, I understand what you are saying.  I was assuming you have source code for the routine and I think that was a wrong assumption.  You want to start the routine, simulate two keypresses with Labview and let it run.
I think you will need to dip into Windows dlls or .NET to accomplish that.  I posted a link in another post earlier today about calling a CMD prompt from .NET (which I think would be possible...not having done it myself).  This .NET function would potentially return a window handle that you could then use to send some simulated keyboard input.  The .NET constructor is System.Diagnostic.Process.  Give it a try and see what happens.
http://stackoverflow.com/questions/691716/running-cmd-commands-via-net
aputman
Message 3 of 8
(8,079 Views)
thanks aputman, I will try it.
Message 4 of 8
(8,074 Views)
You shouldn't have to simulate anything.  System Exec has a standard input for just such an occasion.  Call your bat file in the command line and send the input in through the standard input.  Or maybe I misunderstood you?
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(8,059 Views)
Hello Billko,
You did not misunderstand me. I did that "sending 1 through the Std Input" but nothing happens.
Maybe I am missing something.
Message 6 of 8
(8,025 Views)
@Frank_view wrote:
Hello Billko,
Ugh, I didn't the /k switch.  I'm not sure it works with that switch.
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(7,980 Views)
Accepted by topic author Frank_view
Hello all,
thank you for your responses and contributions. I have a solution which I can now use. I saw a VI made by user "Michael_W." on "Programmatically Simulate Key Strokes in LabVIEW"
I have used one of the VI's to simulate my keyboard input when needed and it works as required.
Attached is a rough and quick implementation with the VI.
Message 8 of 8
(7,952 Views)
