Simulating Start/Stop button Latch behavior
In Labview I am simulating the action of two momentary pushbuttons beings used as a latching Start/Stop circuit.  Attached is my solution.  My question is there a more efficient way to do this?  My solution seems clumsy.
Jeff Beltramo
(3,604 Views)
Accepted by topic author jbeltramo
Hi Jeff,
why do you need the inner case structures? All they do is "IF true THEN true ELSE false" (aka "Rube-Goldberg")…
Once you deleted the inner case structures you can replace the outer one by a SELECT function:
(3,584 Views)
I have never been known for my efficiency of programming Smiley Embarassed
Thank you very much.
Jeff
(3,571 Views)
