Simulating button clicks in sub panels
Hi All,
I want to simulate click for buttons (with latch mechanical action) that are in sub panel VI so as to trigger its action.But I couldn't achieve it in the way I can simulate a click for any other buttons in the Main VI. I have attached a sample program to explain my problem,please let me know what is my mistake.
Thanks in advance,
S.G.Sree Ranjani.
Message 1 of 10
(5,589 Views)
I didn't see the code
But you can register for a user event (Use event structure) in the main vi And then trigger it in the sub Vi that you call in the subpanel.
Regards
Guru (CLA)
Message 2 of 10
(5,567 Views)
Hi Guru,
Thank you but I need to simulate this Click action without making any changes in the VI which I call in sub panel.
Sree
Message 3 of 10
(5,518 Views)
It's an interesting problem.  I downloaded and tried to make it work but was unsuccessful.  I'm only posting to let you know you're not alone in trying this. 🙂
Jim
Message 4 of 10
(5,493 Views)
Accepted by topic author SreeRanjani
just a minor mistake.
Jim you missed it.
Here you go.
Message 5 of 10
(5,467 Views)
Thanks Neos,
I hope this solution will work can you please explain why this change should be made.
Sree
Message 6 of 10
(5,424 Views)
Your post does NOT contain the solution and should not be marked as such.
Please mark the most helpful post as solution, not your own!
Message 7 of 10
(5,414 Views)
Sorry,
I marked my post instead of the previous post
Message 8 of 10
(5,406 Views)
Hi Neos,
Your Solution is working , can you please explain me why the change is made and how it is working now.
Sree
Message 9 of 10
(5,351 Views)
@SreeRanjani wrote:
Sorry,
You can easily correct that at any time, so please do.
Message 10 of 10
(5,332 Views)
