Simulating real time signal from waveform
I'm reading a binary file with signal data. In the file there are signed 16-bit integers, that are values of signal amplitude. The sampling rate of singal was 2kHz.
What I want to do is read whole file and then simulate the signal as it was real time (from an array or waveform). How can I accomplish that?
In the attachment there is the code, that it's not working as I wanted to.
Thanks for any suggestions!
(3,445 Views)
Well first, are the 16 bit integers scaled? If not, they will be way too large to send to an analog output. Also, a good place to start is with the daq examples that ship with LabVIEW.
Mike..
PS I'm sorry I can't look at your code as I'm on my phone right now.
Certified LabVIEW Architect
LabVIEW Champion
(3,422 Views)
Hi!
The integers are not scaled, but this is not important.
I want to simulate the signal as real-time, because I'm going to prepare software for analyzing (phase, power spectrum) that kind of signal,
because getting the real signal is quite hard (its doppler signal of fetal). As soon as I have a software that actualy does somethig interesting I will prepare the enviroment to test the aquiring also.
(3,376 Views)
Hi and welcome to NI Forums!
There are two things I noticed in your code:
  1. The size of the file is in bytes, so it should be divided by 2, not 16.
  2. If you would want to divide the data into chunks (like they are coming from a scope or DAQ card), use the reshape array function, or read it from file inside a for loop.
Cheers:
Andrew Valko
National Instruments Hungary
(3,303 Views)
