Simulation Interface Toolkit 2011 build error
Hello !
I am using Simulation Interface Toolkit 2011 with the following Matlab/Simulink versions:
MATLAB                                                Version 7.4        (R2007a)
Simulink                                              Version 6.6        (R2007a)
Control System Toolbox                                Version 8.0        (R2007a)
Optimization Toolbox                                  Version 3.1.1      (R2007a)
Real-Time Workshop                                    Version 6.6        (R2007a)
Signal Processing Blockset                            Version 6.5        (R2007a)
Signal Processing Toolbox                             Version 6.7        (R2007a)
SimMechanics                                          Version 2.6        (R2007a)
Simulink Control Design                               Version 2.1        (R2007a)
Spline Toolbox                                        Version 3.3.2      (R2007a)
Stateflow                                             Version 6.6        (R2007a)
Stateflow Coder                                       Version 6.6        (R2007a)
Statistics Toolbox                                    Version 6.0        (R2007a)
System Identification Toolbox                         Version 7.0        (R2007a)
I am also using MS Visual C++ 2005 v.8.0.50727.867 and Labview 11.0.1f2 (32 bit)
I can successfully autocode and compile simple models into "nidll" dll targets.  However, I have a larger model that won't autocode correctly.  I get the following error messages:
### Caching model source code
Error: File: C:\SimulationInterfaceToolkit\2011\UserInterface\DLL\tlc_c\NI_SIT_IO.tlc Line: 82 Column: 114
The specified index (3) was out of the range 0 - 0
The specified index (2) was out of the range 0 - 0
The specified index (1) was out of the range 0 - 0
I have simplified my model to few constant-blocks with their SIT Output-Blocks and the Signalprobe-Block . Other similiar models are fine.
Line 82 of my NI_SIT_IO.tlc file is:
  %assign realDataInputPort = BlockOutputs.GlobalBlockOutput[IDNUM(DataInputPort.SignalSrc[sigIdx])[1]]
Any ideas on what could be causing these error messages?
Thank you.
(2,758 Views)
Hi
It should not be a compatebility error. I looked up the list below.
Simulation Interface Toolkit compatebility
http://digital.ni.com/public.nsf/allkb/D174674A91E5536286257428005C2426
Could you please sent an Screeshot of the error?
Best Regards
Jerry
(2,723 Views)
