Simulation Interface Toolkit
Thanks Alessio I'll do that.
Message 11 of 14
(1,288 Views)
Do you have any loops without a timer? If a loop is trying to run as fast as it can, it can hog the CPU. See if even a small delay makes a difference.
Message 12 of 14
(1,289 Views)
Hi Sima,
the VIs that handle the server have been automatically created when I made the DLL so I'm not the author of the architecture. But I quickly looked the diagram's VI and I didn't see no loop without a timer.
I send my files if you wanna chack it out.
Message 13 of 14
(1,284 Views)
Besides that,
does anyone knows how to make a .exe file of the model_main.vi (created with the dll) ?
Because when I create it and I try to run it, the connection with the SIT server doesn't work.
I should probably set, in the settings when creating the .exe file, some of the subVIs to autorun when launching the .exe file but I don't know wich ones I should run automatically.
Thanks.
Message 14 of 14
(1,277 Views)
