Simulation Interface between LabVIEW 2012 & Simulink 2012b
Hello everyone,
I'm working on some control theories so I need to connect between LabVIEW 2012 and Simulink 2012b. I already have SIT installed but I can't find NI Signal Probe in Simulink!
So can I have some help?
Thanks in advance,
Ahmed
(2,890 Views)
Hi Ahmed,
As of right now Simulink 2012b is not one of the supported MatLab versions. LabVIEW 2012 with SIT 2012 supports the following versions:
The MathWorks, Inc. MATLAB® software and The MathWorks, Inc. Simulink® application software release 13.x, 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, 2010a, 2010b, or 2011a
Also, when you ran the installer for SIT I assume you've checked the "MATLAB Support" option in the installer software options menu, correct?
Sev K.
Senior Systems R&D Engineer | Wireless | CLA
(2,856 Views)
