Simulation Interface toolkit and MATLAB R2013a
And Simulation Interface toolkit 2012(32 bits) and MATLAB R2012a (64 bits) are compatible????
Message 11 of 16
(1,969 Views)
From the readme file: Note  The LabVIEW Simulation Interface Toolkit does not support 64-bit versions of the MATLAB application software.
CLD Certified
Message 12 of 16
(1,941 Views)
Hello sir, I am using labVIEW2013 vesion. I need to interface matlab and Vi. So, i was downloaded SIT toolkit 2012. After installing I could not find that tool in my VI.I was searched in tools.  What is the problem with that....
Message 13 of 16
(1,857 Views)
This is very different question from what the rest of the post is about. You'll get more views and better answers if you post your question in a new thread.
I'd also recommend explaining things in more detail for example: What version of LabVIEW you're using, and what's the name of the tool you're missing.
MATLAB®, Simulink®, and Real-Time Workshop® are registered trademarks of The MathWorks, Inc.  All other trademarks are the property of their respective owners.
CLD Certified
Message 14 of 16
(1,842 Views)
Reading your post again I noticed that you mentioned you are using LabVIEW 2013, which is not compatible with SIT. As I mentioned in one of my previous posts, SIT was replaced with MIT in 2013.
CLD Certified
Message 15 of 16
(1,822 Views)
Thank you.....
Message 16 of 16
(1,813 Views)
