Simulation model converter: cannont communicate with MATLAB
No, I am not running Matlab during the installation.
Anyway, I believe I found the problem: I am installing Simulink Interface Toolkit (SIT) 2011, whereas I am running LabVIEW 2010 SP1.
I could not find SIT 2010.
Thank you
Message 11 of 14
(716 Views)
Ok good to hear. I hope it all works ok for you now. If you have any more queries don't hesitate to let me know.
Regards
David B
National Instruments UK
Message 12 of 14
(715 Views)
Well, actually it does not work... I cannot find SIT and Matlab Support 2010 anyware.
Matlab support is not included in the installation DVD, at least not in the Accademic License version.
Message 13 of 14
(713 Views)
Hi Tommpogg,
I have spent some time searching and found some information on how to establish the connection to the SIT server. A startup.m file needs to be created in the location:
C:\Program Files\MATLAB(your version)\
The following lines need to be in the startup.m file:
addpath('C:\SimulationInterfaceToolkit\ModelInterface\tmw');
addpath('C:\SimulationInterfaceToolkit\UserInterface');
addpath('C:\SimulationInterfaceToolkit\lib');
NISITServer;
When you open up MATLAB, the startup.m file may open but if not you can run it after it opens, you should as a result connect to the SIT server and be able to place the NI Signal Probe.
I hope this helps, let me know the result.
Regards
David B
Message 14 of 14
(707 Views)
