Simulation of cascaded control loops
I building a simulation of a motor control system using LabVIEW Simulation 8.2.  The controller has the traditional cascaded position-velocity-current loop design where each loop runs at a different speed.
The online help for Simulation says that simulation subsystems inherit the timing of the main diagram.  How do I set the speed of the inner loops to be different than the outer main loop?
(3,170 Views)
(3,150 Views)
Accepted by topic author mysterj
Actually, I solved the problem using a zero order hold block at the beginning of the subsystem diagram and setting the sampling time to the required period.
(3,137 Views)
