Simulink Interfact Toolkit
Hello Everybody,
I want to use simulink and PXI to control my robots. I want to know if it is possible to use a simulink .mdl file that contains a C based S-function doing things like matrix inversion, optimization etc with the simulink interface toolkit.
Vivek.
(4,320 Views)
Hi Vivek,
One way to control your robots with PXI and Simulink would be to create dlls from Simulink and call them with LV RT.  You would have to map the controls from Simulink to LV using the Simulation Interface Toolkit.  You would of course need LV, LV RT and SIT.
Nadim Rajabi
Applications Engineering
(4,290 Views)
Vivek,
Yes you can use S-functions with Simulation Interface Toolkit.
Since you will be connecting inputs and outputs of your model to signals from your robot you will want the interaction to be deterministic and the simulation to run in real-time.  This means you will be running your model on LabVIEW Real-Time (RT).  In most cases if your code will run in Windows it will run under LabVIEW RT, however some functions may not be supported.  If you are using simple C code it should not be any problem.  If you are including external libraries you will want to check that the code will run.  The best way to do that is to either generate the model DLL using Simulation Interface Toolkit (SIT) and check it using the DLL Checker for your version of LabVIEW that is attached to this Knowledgebase:
http://digital.ni.com/public.nsf/websearch/0BF52E6FAC0BF9C286256EDB00015230?OpenDocument
If you don't have SIT yet, you can test the code by building a standard dll that uses the same code as what is in the S function and then testing that dll.
Carl L
(4,203 Views)
