Simulink model conversion to DLL
Dear All, I want to convert Simulink model to DLL by use Real Time Workshop and nidll.tlc (using this guide: http://zone.ni.com/reference/en-XX/help/371504C-01/lvsimtkhowtoconcepts/simulink-sit_h_convert_model... I setup compiler Lcc-win32 C 2.4.1 by use mex –setup command. When I start building process after few seconds I get error and following messages: >> Real-Time Workshop build procedure for model: 'file_name' aborted due to an error. and: Invalid setting for environment variable MSDevDir or DevEnvDir. The setting is: '' You can verify the setting by checking for the existence of: %DevEnvDir%\..\tools\vsvars32.bat (for Visual C/C++ 9.0) %MSDevDir%\..\..\vc98\bin\vcvars32.bat (for Visual C/C++ 6.0) %DevEnvDir%\..\tools\vsvars32.bat (for Visual C/C++ 8.0) You must define MSDevDir or DevEnvDir to be: set %DevEnvDir%=\common7\ide (for Visual C/C++ 9.0) set %MSDevDir%=\common\msdev98 (for Visual C/C++ 6.0) set %DevEnvDir%=\common7\ide (for Visual C/C++ 8.0) This error may be due to an invalid preference file: C:\Users\admin\AppData\Roaming\MathWorks\MATLAB\R2010a\mexopts.bat Please run "mex -setup" at the MATLAB prompt to correct System configuration: - LabView 2010; - Matlab 2010a - I used Lcc-win32 C 2.4.1 compiler. What should I change to get DLL file of Simulink model? miro
(4,549 Views)
Previous message was completely unreadable. Once again:
Dear All,
and:
The setting is: ''
set %DevEnvDir%=<VisualRoot>\common7\ide (for Visual C/C++ 9.0)
set %MSDevDir%=<VisualRoot>\common\msdev98 (for Visual C/C++ 6.0)
set %DevEnvDir%=<VisualRoot>\common7\ide (for Visual C/C++ 8.0)
- LabView 2010;
- Matlab 2010a
miro
(4,541 Views)
Hello miro,
Can you please tell me the version of Windows you are running and version of Microsoft Visual C++ you have installed?
Best Regards,
Gregor Cerne
(4,503 Views)
Hello Gregor,
Thank you for your response. I have just solved described problem.
I have Windows 7 and (now) Microsoft Visual C++ 2008. This configuration works very good. The problem was caused by previous Microsoft Visual C++ installation: 2010. It cannot cooperate with Matlab 2010a.
miro
(4,496 Views)
Hello miro,
I glad that you solved your problem. I found this site with table describing compatibility between MatLAB, Simulink, Microsoft Visual C++, LabVIEW and SIT - just in case you will have simiral problem in the future:
http://digital.ni.com/public.nsf/allkb/D174674A91E5536286257428005C2426
Best Regards,
Gregor Cerne
(4,484 Views)
