Simultaneous Analog Input and Output using myDAQ
The thing that I see is that the waveform you send to the Analog Write is coming from a feedback node.  On the first run of your VI, that feedback node will give the default value since nothing is wired into the initializer terminal.  The default is going to be an empty waveform.
Beyond that, that node will only run once because it is not inside the while loop.  So there is really no point to having a feedback node at all.
Message 11 of 14
(1,761 Views)
Hello Ravens Fan,
If you don't mind, can you elaborate on what you mentioned? Do you know of any tutorials I can read on that can assist in helping complete what I want?
Thanks in advance
Message 12 of 14
(1,738 Views)
What I essentially want to do is something like this. I understand how most of the configuration is working, except I do not know where exactly I would put the write VI as well as the Harmonic Analyzer VI that I wish to use.rrrrrrr.png
Message 13 of 14
(1,735 Views)
Hello RavensFan,
So I was able to configure my VI in this manner. When highlighting the execution, it works for the first few iterations and then I get this error. I am unsure on how to handle the error. Any suggestions? I have attached the a snippet and a VI for your reference. Thank you in advance. I appreciate the help. dddd.png
Message 14 of 14
(1,722 Views)
