Simultaneous Routines
Good afternoon,
We are building a robotic boat to clean the waters. We realize that there is a number of routines that need torun simultaneous.
What do you recommend to do?
Thank you.
manolo
(3,759 Views)
Hi manolo,
Run this "number of routines" simultaneously!
Have you heard about DATAFLOW? It's all you need…
(3,675 Views)
Here's what Gerd was talking about.  Here are two While loops, running simultaneously in parallel.  The only Data Flow shown here is the Error Line going in, meaning that these two loops start at (approximately) the same time, then run independently.
Parallel Loops.pngBob Schor
(3,639 Views)
Yes, you need parallel processes.Check here for some ideas:
http://www.notatamelion.com/2014/10/07/build-a-proper-labview-produceconsumer-pattern/
...and the following few posts.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,624 Views)
