Simultaneous analog input/output
Hi all,
I need to output two different DC signals, and several analog waveforms, while at the same time acquiring analog input. I'm using a cDAQ 9178, with NI9264 for AO, and NI9220 for AI, and LabView2014.
I'm getting Error -201105: Possible reason(s): Resource requested by this task has already been reserved by a different task with conflicting settings. Unreserve any other tasks using this device, or change their settings to be compatible with this task. From an example that I thought was similar in a way ( https://decibel.ni.com/content/docs/DOC-11632 ), I reserved one of the tasks (and forced it to start last), but the error is the same with or without the DAQmx Control Task vi.
Any ideas?
Thanks in advance!
(3,666 Views)
From further reading of the forums, it sounds like what I want to do may not necessarily be possible because of clock issues, and that I should have only one task for all the AO channels. My issue with this is that with two separate channels, I can use "Nchannel 1sample" write task for the DC signals, and I can easily change the value while the task is running.
So I guess my new question is: how can I combine two DC signals that I want to be able to change "live", with buffered waveforms?
Thanks!
(3,630 Views)
Hi Nathan,
Could you add your vi to your post and I'll see if I can replicate the error your having.
Cheers James
(3,509 Views)
