Simultaneous dual peak counting (coincidence)
Hi. I have been counting peaks using labview with the help of a simulated signal. Just one. What I have to do now is make another simulated signal and test coincidence--how many times these two signals cross a certain threshold at the SAME time before I stop it. Anybody have an idea how I can go about that? Thanks in advance!
(2,749 Views)
Accepted by topic author MrIncredible
If we're doing this in software then I would suggest first comparing the signals to a threshold and outputting a boolean value to indicate a crossing.  Then compare those boolean values to see if they're both true.
Please let me know if this is would work out.
Bobby Breyer
(2,714 Views)
Yes, it did work! Thank you 🙂
(2,708 Views)
