Simultaneous updation of sine wave using 2 PXI-6711 cards using RTSI Trigger
Hi ,
How to generate continuous sine wave using two pxi-6711 cards at same time without any phase shift using traditional nidaq functions.
satya
(3,096 Views)
What programming language are you using? And why do you want to use Traditional NI-DAQ as opposed to NI-DAQmx?
-Alan A.
(3,093 Views)
i have alredy done my application using tradtional daq so i want use tradtional daq vi's.
(3,089 Views)
What programming language? LabVIEW? CVI? And what version?
-Alan A.
(3,083 Views)
labview 7.0
(3,070 Views)
In LabVIEW, go to Help>>Find Examples. Navigate to Hardware Input and Output>>Traditional DAQ>>Multiple Device. There is an example there called "Two E Series Shared Scan Clock". That example is for analog input, but you should be able to modify it to be for analog output. Basically you will just have to share the scan clock from one board(master) and use it as an 'external' clock for the other board(slave).
-Alan A.
(3,055 Views)
