Simultaneously Record Multiple DAQ Channels
I am currently set up to read two channels in from the DAQ using DAQ Assistant. I am wondering what the best way would be to go about sampling these channels at the same time, or as close as possible. Attached is the vi I am currently using.
Sawyer
Message 1 of 8
(5,365 Views)
I having the same problem. I need to make a program that can log data from 4 sensor at the same time. Running individually have no problem but when i try to run all at the same time there is an error.
Message 2 of 8
(5,361 Views)
Sawyer
They are sampling at the same time (or extremely close to each other).  I'm not sure what your actual problem is.
Message 3 of 8
(5,346 Views)
Any particular format you want to save your data in?  I recommend TDMS since there is a very handy Configure Logging function in DAQmx to save your data to disk (TDMS file) as you read it.
Message 4 of 8
(5,344 Views)
I was just wondering if there was a way to get them closer, or if this way is good enough.
--Sawyer
Message 5 of 8
(5,342 Views)
Reading the two channels in a single task is going to make them as close as possible in sampling time.
Message 6 of 8
(5,340 Views)
Accepted by topic author ssward
DAQmx handles all the timing under the hood and does pretty well.  If you want to tweak the advanced timing settings you can but of course you'll have to give up the DAQ ASSistant and write real LabVIEW code. Smiley Surprised
I'm assuming you're using a multiplexing card right?  The only actual solution for true simultaneous sampling is to buy a card that has multiple ADCs like the S-Series cards.
To the second poster:  You don't have the same problem as the OP.  He can set up multiple channels.  If you want help, you need to provide more information than "it gives an error". Smiley Wink
EDIT: I'll bet you're trying to use separate tasks for every input aren't you.  You'll get a resource conflict error if you do.  You have to use ONE task and set up multiple channels in that task to collect more than one signal.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 7 of 8
(5,337 Views)
Thanks for the information.
Message 8 of 8
(5,326 Views)
