Hi Yong,
Congratulations with posting your first question on the Discussion Forums!
Regarding your VI, and the missing data; here are some tips:
- Make sure that you see the data in the DAQ Assistant setup dialog when specifying the tasks.
- When running the VI, click on the wires from the DAQ Assistants
to probe (use the Graph) if there is any data flowing through them.
Make sure that the expected data is sent from the DAQ Assistants.
- Instead of having two separate analog input DAQ Assistants,
specify the two channels "pressure1_Pr2" and "flow1_6SB123_ai0" in one
DAQ Assistant, by clicking the small "Add" button inside the DAQ
Assistant setup.
- If it still doesn't work, remove the analog output part of the code to see if that helps.
Let us know what you get with the above recommendations, thanks.
Have Fun!
- Philip Courtois, Thinkbot Solutions
