Simultaneously inputting into local variable of a Numeric control whilst maintaining control.
I think your code is very misguided and confusing. It is peppered with useless events for controls on the subVI front panel which is never visible anyway. While I personally would probably do the event handling in the main VI, here's a working version of doing the event handling in the subVI. Seems to work just fine. Let me know if you have any questions. (LabVIEW 2012).
Message 11 of 13
(988 Views)
1cecream wrote:
I thought I might warn you that Altenbach's original "MotorControlSpeed(with_event)MOD2" also has some kind of error that I didn't quite understand. What I found was that if I press OFF on the speed selection control, a value of (1/4)64 is inputted into the knob, and if I press 1/4, a value of (1/2)128 is inputted into the knob (i.e the two are out of sync by 1 increment). Not necessarily solving the issue, I was able to put a quick fix to this by manually rearranging the buttons in the speed selection cluster control (I am using this solution for my top-level and SubVI compilation). I still have no idea why this was occurring in Altenbach's original VI, because the initial arrangement of the clutser controls (0-OFF, 1-1/4, 2-1/2, 3-/3/4, 4-FULL) was right.
That's because we also allow "no selection" for the radiobutton control. Here 0 is no selection and everything is shifted up one. You need to insert +1 or -1 in the right places to adapt to that (the code I just posted does that).
as a start, try to add a "-1" as shown in the picture below. 😉
Message 12 of 13
(987 Views)
Hi Altenbach,
Thank you for this!!! After looking at your VI and the remarks you made I completely understand why the increment is needed there now; in fact I was wondering why even after I rearranged the cluster control the "OFF" selection would not activate for the "Motor PWM Speed" event card. Additionally, I clearly misunderstood the use of reference nodes which Is why so many superflous elements existed in my VI. I would have wanted to keep the event structure portion of the code as part of the top-level VI, but because I'll be using this particular event structure for many controls, I figured it would be beneficial to change it to a SubVI should I need to modify anything in the future.
Again thank you for your time & consideration!
Message 13 of 13
(972 Views)
