Simutaneous use of elapsed timer and user click requirement
I have trouble to program this: I would like that after a certain number of clicks in the screen made by the user, a message appears. No trouble with this, I am able to do this. But I would like that if he does not within x sec the VI stops. I use elapsed timer express vi for this and I compare elapsed time with x sec. I used a subvi for the click requirement.
In this way the elapsed timer works well but not the click requirement. If I program each thing separately the vi both works but when together it doesn't work.
Help would be appreciated. Thank you in advance.
Message 1 of 19
(3,913 Views)
What version of Labview do you have?
JM
Message 2 of 19
(3,905 Views)
8.0
Message 3 of 19
(3,899 Views)
Hi nousome,
Do you have access to event structure?
Message 4 of 19
(3,895 Views)
Base or full version?  If you have the full version you can use event structure.
JM
Message 5 of 19
(3,894 Views)
Yes I can use event structure but I have difficulties to use elapsed time with this.
Message 6 of 19
(3,889 Views)
I had some difficulties to save this VI in LV8.  Let me know if you could not open the VI.
Jean-Marc
Message 7 of 19
(3,881 Views)
Jean-Marc
Won't increasing the time out to 5 seconds work in itself?
Message 8 of 19
(3,871 Views)
Put the number of seconds you want.
JM
Message 9 of 19
(3,867 Views)
Thank you very much it works fine.
Message 10 of 19
(3,841 Views)
