Since upgrading labview many sub vi's (such as DIO Port Config.vi) are missing
I have recently upgraded Labview from version 8.0 to 8.2. Now my vi's will not run because they are unable to find sub vi's.
The missing vi's include
DIO Port Config.vi
AO Clear.vi
AO Clock Config.vi
Route Signal.vi
AO Confic.vi
Continuous Pulse Generator Config.vi
RTSI Control.vi
and many more.
Are these vi's located in a different place in the new version of DAQ?
Can you recommend a quick fix to this problem?
(3,362 Views)
When you do an upgrade, old drivers are not automatically copied from the old installation to the new and I don't think tradtional DAQ is automatically installed when you run the driver's CD. You can re-install traditional DAQ or copying the files from the 8.0 folder to the 8.2 folder should also work. You might also want to think about replacing the old DAQ functions with DAQmx.
(3,352 Views)
