ā09-17-2005 05:11 AM
ā09-19-2005 07:32 PM
Raghunathan -
The answer to your first question really depends on what exactly you are "expecting" the VI to do in the first place. It's probably best in your case simply to think of the timed loop as nothing more than a while loop with a built-in delay. Thus, in your example, one iteration of the loop will execute every 50 ms. The loop timing has nothing to do with the sine wave generation or the way that data is output from the DAQ card, so to answer your second question, the timed loop itself will have no effect on the sine wave frequency that you write to the card in "State 2".
Kind Regards,
ā09-19-2005 09:01 PM
ā09-20-2005 07:12 PM
ā09-20-2005 08:31 PM
