Sine Wave to Square Wave
Hi All
Im trying to create a VI that converts a sine wave to square wave with unsymetrical switching points. So far ive created a VI that does it symmetrically but cannot for the life of me figure out how to do it asymetrically.
I want a HI when the sine wave is greater than +0.41 and switch low when the sine wave gets below -0.14
Can anyone help.
Ive attached my current VI to this message.
Thansk
Message 1 of 8
(5,674 Views)
Hi JW,
so you want a switch with a hysteresis?
I would use one with a switch point at +0.135 and a hysteresis of ±0.275: switching to HI at (switch point + hysteresis) and going LO at (switchpoint - hysteresis)…
Message 2 of 8
(5,662 Views)
Use a shift register to maintain which value should be output of the loop.  When the value goes above 0,41, change that value to 1.  When it is less than -.14 change it to zero.  When it is in between, output whatever value of 0 or 1 is still in the shift register from the previous iteration
Message 3 of 8
(5,660 Views)
How do i do this can you explain
Message 4 of 8
(5,656 Views)
can you show me how to do this.
Message 5 of 8
(5,654 Views)
Yes.  But it is better if you try for yourself.  It is a a shift register and a couple select statements.
I'll give you the start and you can figure out how to put in the 2nd part.
Message 6 of 8
(5,644 Views)
A ranged case structure could work as well.  Not quite as flexible, but can be simpler to understand.
Message 7 of 8
(5,615 Views)
OK, your question can be summarized as follows:
  • If Input >0.41, output = Hi
  • If Input <-0.14, output = Lo
  • Otherwise, output = former output.
The key concept here is the third step, having the next output be the same as the previous output if the input is somewhere in the middle.  Do you know about While Loops in their "Do Once" mode with Shift Registers (sometimes called a "Memory")?  If you configure one such thing, you can put two Case Statements inside it to handle the "forced Hi" and "forced Lo" conditions, with the "otherwise" being the former output living on the Shift Register.
If none of this makes any sense to you, spend some time with the LabVIEW Tutorials (look in the upper right corner of the LabVIEW Forum Home Page).
Bob Schor
Message 8 of 8
(5,589 Views)
