I'm using Labview 8.2.1 and I'd like to output a sine wave voltage to a motor. I've been mainly using the 'Cont Gen Voltage Wfm-Ext Clk.vi' within the example library. The only issue is I'd like to start from an arbitrary voltage level U to output a sine wave which is not necessarily centered about 0 but rather oscillates between U and U+deltaU, deltaU being any value. I've tried to retrieve the way the sine wave is generated through the example program but I couldn't figure out how to modify the 'NI_AALBase.lvlib:Sine Wave.vi' subvi - which seems to generate the sine wave array from a Call Library Function node I was unable to change... Is there a simple way for me to work around this?
Thibault.
