Sine wave with phase shift
Hi.
I'm trying to make a sine graph with adjustable phase shifts. The idea is that whenever I change the phase shift during runs, the graph will reset and make a new graph with the new phase shift. I am currently able to construct the sine graph, but I need to stop the run, change the shift, and run again to see the change in shift. How can I fix this?
(3,363 Views)
Can you post what you have so far?
Is hardware involved?
Norbert
Norbert
Expert: Geometry
(3,356 Views)
This is my default program since I don't know what to do next.
(3,347 Views)
You should learn about some basic stuff in LV. Please add a wait time in the loop, your VI hogs the CPU (100% load of at least one core).
The next step in your program is to extend it to a state machine. Put some buttons on the UI to set the phase or to "replay an automated phase shift".
Norbert
Norbert
Expert: Geometry
(3,341 Views)
