Single-Process Shared variable HELP!
I can't believe I've been trying to figure this out for days... I'm sure I'm missing something trivial.  So I want to do something super simple.  I have a main program (.exe) that spawns different subvi's (using call by name function).  I have a variable that I want to update in one of the subvi's and then read it from a different subvi.  So I thought I could do that with a shared variable.  I created a single-process shared variable (since I'm only communicating within the same PC) and everything seems to work okay in the development PC.  But when I install my exe in my target PC my variable doesn't update anymore!  What am I doing wrong??
By the way, I'm using Labview 8.5.1.
(5,407 Views)
Did you install Installer>Additional Installers>NI Variable engine in your target machine?
PaulG.
Retired
(5,401 Views)
Yes, I did installed the SVE in the target machine.  It still doesn't work 😞  Do I need a network-published variable for what I'm trying to do (pass data between 2 vi's on same PC)?
(5,398 Views)
I had this same problem when working with LV 8.6. I believe my solution was to programmatically deploy my shared variables at the beginning of my application.
(5,373 Views)
I switched to a network-published shared variable (although I'm not sure I need it) and then try to programatically deploy it at the beginning of my program.  I kept getting an error that I couldn't write to the file when trying to deploy the library.  I turned off the firewall and even remove the antivirus altogether and nothing worked.  Maybe is a Windows 7 thing?  Anyways, I ended up (finally, after much poking around because step-by-step documentation on this is NON-EXISTENT!!!!) starting the SVE, and deploying my library and variable manually using the Variable Manager.  It is now working but I will still like to figure out how to deploy programatically in case my program ever needs to be installed on a different PC by someone that is not aware how to deploy shared variables manually (which is very likely to happen).
(5,358 Views)
Then you'll need to post your code or at least a screenshot of how you are programmatically deploying the variable library.
(5,340 Views)
Did you read this link?
PaulG.
Retired
(5,330 Views)
