Single Pulse
I'm trying to generate a single pulse (preferably delayed) that is triggered
by a simple switch or (preferably)keystroke. The width of the pulse needs
to be 1ms. Is there a way to generate just one pulse of such small width?
I'm using an E-series board, and wish to send the pulse out of one of the
DAC pins. Any suggestions?
(2,917 Views)
I am pretty sure you can, but that depends on a particular E-series board
you have.
Check the spec sheets and see what the update rate for the DAC is, also look
at the settling time.
In general in about 30min with a scope you should be able to determine the
answer even if you do not know the specs, which are on the NI website.
Reinis Kanders
"Vladislav Zilberman" wrote in message
news:39510636@newsgroups.ni.com...
triggered
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(2,917 Views)
