Single-ended signal with SCXI-1314?
In MAX I only see the option to read differential signals with the SCXI-1314 attached to a SCXI-1520. Is it possible to read a single ended nonreferenced signal with these components? If so how would you set it up?
(2,601 Views)
Hi CSN,
For future reference, this type of question would be more appropriate to post in the Signal Conditioning forums.
 The SCXI-1520 is a strain gauge module, and as such, was designed solely for differential (bridge) measurements. Chances are, there's a more appropriate DAQ device for your application. What type of signals are you trying to measure?
Mark E.
Precision DC Product Support Engineer
(2,585 Views)
Thanks for replying Mark E.
The sensor is full bridge with an output of 2 - 6 volts. The sensor has three wires - power, output high(+), and output low(-). I had thought this was a differential signal but the sensor manufacturer tells me the output low(-) should be wired to the DAQ ground. This leaves me thinking it is a single ended signal not a differential. I was hoping to wire the high(+) to S+ and the low(-) to the ground in the 1314 and be OK. Would this work? Advantage and disadvantages?
If not I have a USB-6229 but it is not currently tied into this system and I was hoping to avoid additional programming at this point.
(2,578 Views)
CSN,
Do you have the data sheet for the manufacturer? I have never heard of a full-bridge sensor that only has three outputs. If the output low is also the ground, then you only have one leg (resistor) from power to ground, so I can't understand how that could be considered full-bridge. To answer the question of whether or not it would work, I have only to say that I can't see how it would work at all as a full bridge sensor.
Mark E.
(2,557 Views)
