Sinusoidal generator
I want to apply sinusoidal input to a control setup via serial port. I am passing commands and input to the setup in string format.
The data type of the LabVIEW sinusoidal generator does not match with the required one and I am unable to type cast also. Please guide. Thanks.
(2,655 Views)
It's hard to guide without knowing the two different datatypes.
Maybe you can post your VI.
(2,644 Views)
