Hi All,
I am using SIT 3.0.3 with LabVIEW 8.2.1. For had been facing a problem where each time I start the host VI the control & indicators would change their ranges. Especially the waveform charts used to change a lot for example the plotting area inside the chart would move a lot to the left making the scale invisible. Which makes it very difficult to understand the signal. Then I would the following KB article which solved a part of the problem.
http://digital.ni.com/public.nsf/allkb/234E19202757CFE8862572AE005559A2
But even after modifying the labview.ini file as mentioned in the KB still the waveform chart changes each time I remap the mappings using Connection manager and the I have to manually make all the adjustments again. Is there a way that I can avoid the automatic readjustment of the indicators and keep size, range shape etc intact.
Thanks and Regards,
Vicku.
