Skipping password-protected VIs during a LabVIEW search
When I search all VIs in memory, and some of them are password-protected, I have to click a dialog box for every single VI. This drastically slows down my searching speed. Is there a way around this, like skipping password-protected VIs during a search?
Bruce
(2,831 Views)
Hi bmihura,
If you are iterating through the VI's yourself, you can use the Get Lock State method from a vi reference to check if a VI is password protected (or just locked).  Check the attached image for a trivial sample.
Joe Z.
Edit:  I missed the operative word: search!  In my version of LV (7.1) there doesn't seem to be a way around the password issue.  Perhaps another can offer better advice.  Sorry!
Message Edited by Underflow on 09-28-2006 06:53 PM
(2,816 Views)
Yes, I've seen that too with LV7.1.
I don't know any tricks around that..  😞
(2,809 Views)
LabVIEW asks for the password of some vi's ONLY when the vi is not used anywhere! This seems like a bug to me: if the vi is somewhere, the search is ok, if it's not used, the search is not ok.
The only workaround I can think of, is placing the VI in a new diagram, and use All Instances, or a search. You know the VI is used at least once, so the search will be fast...
Wiebe.
"bmihura" <x@no.email> wrote in message news:1159481408007-421846@exchange.ni.com...
When I search all VIs in memory, and some of them are password-protected, I have to click a dialog box for every single VI. This drastically slows down my searching speed. Is there a way around this, like skipping password-protected VIs during a search? Bruce
(2,763 Views)
