Slice array
Hello!
I´ve been searching and reading for hours - but probably in the wrong places. I think this is piece of cake for many of you: I now got a small example of what I want - to measure multiple "runs" (up to 10) and display them over each other in an XY graph. Now I want to slice out and separate the different measurements again, but dont know how. Should I use shift registers instead? - didn´t seem like a smart way to do it. Any suggestions? If this is too trivial - please point me in the right direction of an example code.
Thanks!  /Martin
"Physician, researcher and programmer wannabe."
(4,099 Views)
Accepted by topic author madoc
First, you should probably initialize your shift register.
To get one single plot from the array, use index array.
(4,086 Views)
Embarrasing - should be able to figure this out myself...
Anyway:  Thanks again Altenbach! Problem solved.
Martin
(4,070 Views)
