Slider for Display and Control Time of Video
Hey Community,
I run a Video with the IMAQ/ AVI components. Therefor i want to have a timeband as there is one in a normal video player. The Time runs and if I click on the band the video should jump to this moment of the video. Is there a possibility to manage that or do i have to seperate the display of the time and an extra Control to jump to the point of interest?
In the file there is a little example what i mean. (LabView 2010)
Thanks Philipp
(2,944 Views)
hey,
although I do not have the imaq pack, this example looks a good place to start:
https://decibel.ni.com/content/docs/DOC-15136
__________________
Engage! using LV2015
(2,911 Views)
Thanks for that tipp. That's quite what I mean. But in that VI there is the problem that you cannot change the framerate band while the .avi is runnig. That 's my aim.
Lg Philipp
(2,898 Views)
Accepted by topic author PhilippZani
Hi Philipp,
you could do that by modifying the "Read AVI File Example.vi" (see Screenshot). I also attached the VI saved with "For previous version", I hope that works for you too.
This example uses the "IMAQ AVI2 Read Frame VI" function where you can specify the desired frame. So you only have a control that can modifies the current frame, which is normally incremented every loop iteration.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(2,856 Views)
Thank you very much 🙂
That was what i wanted to. Now i can finish my vi.
Great help.
Lg Philipp
(2,834 Views)
