Slow Execution Time of Exponential Function
Personally,I doubt that the difference is in parallelization. I definitely would not want for the exponential function to do this. I typically like to parallelize on a much coarser level.
I don't think that LabVIEW uses anything special, probably just Intel MKL libraries. Maybe it is possible that the way it is called inside the LabVIEW primitive does not take advantage of SSE when operating on arrays (see. e.g. the speed differences here), while matlab does. Just wildely guessing....
I'll try to investigate more....
Message 11 of 20
(1,666 Views)
Since my parallell test still wasn't as fast as Matlab i assume there's something more, probably like the SSE you mention. I'll see if i can get the AMD math core to function, it sounds cool.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 20
(1,655 Views)
I have tested the paralellism as you suggested. It speeds up the computation to around 500ms which is twice faster than before. The computer I used has 4 cores but I am not sure why the speed is only doubled.
One question regarding the paralellism. What happens if inside the parallel for loop, I make another one for loop with parallelism? When I tried this configuration, I get around 350ms. I am asking this because previously, I have tried this configuration in other program and the result was worse than single for loop. The result is unpredictable. =(
Message 13 of 20
(1,627 Views)
You should typically only parallelize one loop, preferably the outermost one. I'll do some testing...
Message 14 of 20
(1,617 Views)
Setting up a parallell loop has some overhead, and if the work time is very small, it'll be a loss. That's why it's typically easier and safer to parallellize the outmost loop. Just like it's usually better to use the array versions of functions in LV compared to placing a scalar version in a loop. This seems to be an exception.
I'll attach a changed test-vi. What i notice is that there seems to be some issue with how the function handles arrays, as the fastest is a double loop with the outer parallell!
See what results you get.
/Y
Qestit Systems
Message 15 of 20
(1,594 Views)
Disabling debugging results in an infinately faster vi.  (Dead-code removal)  You really need an indicator on the data.
Matlab has much lower debugging overhead
Message 16 of 20
(1,570 Views)
I was always testing with debugging disabled but placed an "add array elements" with a scalar indicator after the sequence structure to prevent dead code removal.
The times were basically identical. That's not it! There is no debugging overhead if the bulk of the time is spent inside a single primitive.
There is no reason why the LabVIEW function could not approach the speed of the matlab function unless matlab uses some shortcuts that give lower precision. I still believe it is an SSE issue.
Message 17 of 20
(1,562 Views)
I just disabled the debugging stuff. I tested the program with different configurations. Below are the results.
No loop - ~980ms
single loop with no parallelism - ~1210ms
double loop with no parallelism - ~1340ms
Single loop with parallelism - ~460ms
double loop, outer loop parallel, inner loop normal - ~365ms
double loop, outer loop normal, inner loop parallel - ~485ms
double loop, both parallel - ~400ms
I think the timing is almost the same although the debugging is disabled. Not affected much.
p/s: Yamaeda, I could not open the program you attached. I use Labview 2011 =P. Anyway, thanks a lot everyone for the effort.
Message 18 of 20
(1,535 Views)
2011 version attached.
For me, the 2D array directly is ~3x slower than the other alternatives, with dual for loops with the outer parallell being the fastest. 2011 is actually slightly faster on the 2D array than 2014, but the parallell loops are slightly faster on 2014.
You have the same order in speed, though my parallell loops are slightly faster due to 8 cores. I didn't bother about non parallell loops. 🙂
/Y
Qestit Systems
Message 19 of 20
(1,515 Views)
/Y
Attached is my result using your program. The rank seem consistent as previously, but I wonder why each of them took significantly more time than when using my program.
Also, this still does not solve the issue where the exponential function execution is much slower than matlab. =(
Message 20 of 20
(1,500 Views)
